What are my options?
Old Feb 2, 2003 | 03:39 PM
Rodrigues's Avatar
Unhappy What are my options?
When I was removing the hub the smaller bolt I was using to push against the crankshaft buckled and I think damaged some threads. Other than that the entire cam install went smoothly (new XE 224/230 is in the engine now) What can I do? How much will this cost me? I tried putting the original bolt back it and after a couple threads it just gets stuck and when I take it off it shaves part of the outer threads on the bolt off. I dont need a new crankshaft do I?
Old Feb 2, 2003 | 03:47 PM
Smokn '94 Z's Avatar
Lightbulb
Run a tap into the crank shaft to clean it up. That is what I did. I believe it is a 7/16 -20. Use a bottom tap.
Old Feb 2, 2003 | 03:55 PM
Rodrigues's Avatar
Thats what I was thinking, I wasnt sure if the crankshaft metal was stronger than the tap though.
Old Feb 2, 2003 | 04:06 PM
drop top steve's Avatar
A tap and some cutting fluid, go slow and should be able to save it.
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 14, 2015 02:02 AM
