93 Z28 Will I benifit from Heated O2 swap?
Old Feb 2, 2003 | 11:04 AM
rickyzZ28's Avatar
In my LT1 swapped 90 RS would I benefit from swapping from my 1 wire O2s to the heated 4 wire O2's. The motor is from a 93 and has mods if it matters. What are the benefits to doing this? My friend thinks it would be a good idea but I am not sure as to why I would benefit so I figured I would ask you guys.
Old Feb 2, 2003 | 09:44 PM
rickyzZ28's Avatar
No one knows anything about the swap huh?
Old Feb 2, 2003 | 09:56 PM
speedmiser's Avatar
If you're not having any problems getting readings from the single wire O2's, then I dont see how heated ones would make any difference.
Old Feb 2, 2003 | 09:58 PM
89irocz23's Avatar
might just go into closed loop faster
Old Feb 2, 2003 | 10:53 PM
Soma07's Avatar
With shorty headers you're probably fine with the single wire O2's. The car will probably go into closed loop faster with the heated units but aside from that I dont see it benifiting you any.
FWIW I only converted my car to Heated O2's because of the longtube headers and even then I had problems.
Jan 23, 2015 01:13 PM
cmdeshon
Jan 4, 2015 11:15 AM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
cryptopsy
Aug 19, 2002 12:19 PM
