I want street legal true duals!
Old Jan 31, 2003 | 08:04 PM
thebrainhart's Avatar
Thumbs up I want street legal true duals!
I will be getting tax refund soon, and want to spend a chunk of it, so I think I want true duals. It needs to be street legal though, as my Z is my daily driver. I checked local laws, and as long as cats are used, it is legal, no matter where they are.
Questions:
1. X or H pipe?
I hear an X is better, if so, then
2. Which type of X pipe?
this type: http://cgi.ebay.com/ebaymotors/ws/eB...category=33633
or this: http://cgi.ebay.com/ebaymotors/ws/eB...category=33633
or this: http://cgi.ebay.com/ebaymotors/ws/eB...&category=6771
or other?
3. Which long tubes? Do any come with emissions crap attachments?
4. What material should it be? Aluminium, stainless steel, other?
5. I'd like to go out the back, either over or under the axle, what do you suggest?
6. Where are the best places to get all these things?
Thanks!
Old Jan 31, 2003 | 09:43 PM
D James's Avatar
Re: I want street legal true duals!
Questions:
1. X or H pipe?
or other?
Thanks!
1. X is better, exhaust likes to flow in as easily as possible, the H makes the flow turn 90 degrees, which isn't as efficient as X
it will make more power maybe 5-6 horses more.
2. They all do the same thing, I would get the one that is cheapest
3. Those new Jet Hot longtubes are supposed to include them, and if I'm not mistaken cheaper than Hookers
4. depends on what you want, how much your willing to spend and how you want it to look. for daily driver I would just use aluminium
5. under the axle is out of the question, cause you cannot raise the car with a jack, doing so would allow the rear end to pull down the exhaust and bend them. Jack up your car to see what I mean. Taking them out all the way will be very expensive, I was qouted 350 dollars just to go over the rear end. I went with short side exit pipes, most people choose turndowns
6. Depends on what your doing, are you planning on doing all the work yourself? I know some people have done it real cheap using summit parts. good luck
Old Feb 2, 2003 | 10:19 PM
Ok, then:
1: x-pipe
2: whatever works for my design
3: either Hookers or Jet Hots? What about ceramic coating? is it really needed/worth it, or just a plus.
4: Aluminium, for cheapness? I won't be racing other than the street, so this will do, right?
5: Hmm, I don't think I want to dump down before the axles, anybody have pics of side exits? I also heard that you can use that flex piping stuff, although it leaks a little. But that doesn't matter, because it will have gone through the cats/mufflers already. Any ideas/suggestions?
6: ???????
F'n1996Z28SS
Aug 23, 2023 11:19 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
alphaauto
Jan 22, 2015 08:02 PM
