Autocross and Road Racing Technique There is more to life than a straight line
Alignment needed after shock install ?
Old Jan 31, 2003 | 05:00 PM
RobK's Avatar
Question Alignment needed after shock install ?
After waiting since November, my revalved front Bilsteins finally arrived last night. Do I need to do an alignment after the install?
-Rob
Old Feb 1, 2003 | 01:05 AM
Dr.Mudge's Avatar
For shocks it shouldn't matter, if changing ride height with springs, yes.
Old Feb 1, 2003 | 01:16 AM
WOT's Avatar
WOT
I didn't get my car aligned after I installed Bilsteins-and it drove just the same. However, there was a note included in the boxes that said to get the car re-aligned after putting on the shocks.
Old Feb 3, 2003 | 05:43 AM
Norm Peterson's Avatar
The time that you'd do an alignment after installing shocks is if the new ones are gas pressure, particularly if they're high-pressure units (Bilsteins, KYB Gas-A-Justs, etc.). The assumption goes that the old ones were non-gas pressure, low-pressure gas, or that the gas has leaked out, hence your new ride height would increase slightly with the new ones. It's this ride height change that warrants at least a check on your alignment settings.
Norm
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Hurin
Dec 13, 2014 07:38 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
