Belt Size Needed
Old Jan 31, 2003 | 09:51 AM
foggerZ's Avatar
Thumbs up Belt Size Needed
Hey guys i was just wondering if anyone knows right off hand what the belt part# is for the A/C compressor pulley delete. im supposed to pick it up today, and would like to get them swapped out this Sunday. Thanks.
Old Jan 31, 2003 | 12:16 PM
96ZED28's Avatar
You can use a new stock one, I did and it works fine. Do a search on here, it has been discussed many times. I wrote down the different belts and sizes that work from previous posts, hope these help.
Goodyear 4060635
Goodyear 4060630
Kelly Springfield 625K6 (62.5" 6 rib)
Good Luck
Colin
Old Feb 1, 2003 | 03:11 AM
foggerZ's Avatar
Talking
Thanks for the info colin. I happen to have just recently replaced the belt on my Z.So if the stock one fits i'll use it then. Does the tensioner still keep the belt pretty snug? I just figured that it would need a slightly shorter one, being that the pulley is smaller than the one on the compressor. Thanks for all your help.
Old Feb 1, 2003 | 07:27 AM
96ZED28's Avatar
Even though the pulley is smaller than the compressor pulley, you will notice that the a/c delete pulley is off center on the bracket. What I'm trying to say is where the belt makes contact with the compressor pulley it is the exact same position where it makes contact with the a/c delete pulley. I hope I didn't confuse you it's kind of tuff to explain, but in the end the stock one is fine.
Colin
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
