Every Damn Day!!! Ses Light!@$!@#$
Old Jan 31, 2003 | 08:05 AM
Hyperspeed97z28's Avatar
Angry Every Damn Day!!! Ses Light!@$!@#$
This damn SES light every morning po412, p1641, p1642! then the same 3 codes again for a total of 6 popped codes!!! GRRRRRRRRRRRR this is so annoying! only when the car is cold for its first start of the morning, I could re start it again in the afternoon and it'd be fine, no code. I HATE THAT DAMN AIR PUMP! thats my guess as to whats causing this MESS! what can i do to fix it? just unplug the air pump ? so that it stops blowin the fuse to my fans ?
Old Jan 31, 2003 | 05:38 PM
Anyone ?
Old Jan 31, 2003 | 06:22 PM
moparman's Avatar
If it is the air pump, there is a recall on them. Check with a dealer and see if they have the replacement in stock. It's free.
Old Jan 31, 2003 | 06:33 PM
RamAir95TA's Avatar
Pull the AIR pump harness and it'll go away. As long as the fuse is good...
Old Jan 31, 2003 | 10:58 PM
Fast Caddie's Avatar
Won't removing either the AIR or EGR send a code on OBDII cars? I think you can remove it after having programmed out of the PCM and not get any codes.
cmyname1
Feb 16, 2015 08:33 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
