the daze of our lives
Old Jan 31, 2003 | 01:03 AM
rage366's Avatar
first of all, i posted this in the programming section, but it turns out that it's not frequented by members, must have some kind of an invisible force-field.
i've been trying to run flshread.exe, but as it starts reading the pcm, it says, " terminal error has occured. this program will now shut down. code 72."
i've tried it with 3 different PCM's, and it says the SAME thing for all of them....not only does the error occur while reading the PCM, but it also freaks the pcm out, and makes it shut down...and ofcourse, i have to disconnect the pcm to get it back to normal again.
has anyone had a problem like this before? what is the remedy?
my PC is a 1.8 Ghz with more RAM than it knows what to do with, so i know that's not the issue. the only thing that comes to mind is that there might be an error in the flshread.exe.
--shokor--
cmsmith
Sep 14, 2015 09:25 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
USN06
Sep 7, 2015 03:30 PM
maverickmk
Sep 1, 2015 09:17 PM
