Rear susp clunks when making slw turns
Old Jan 30, 2003 | 04:56 PM
97' Drone's Avatar
Unhappy Rear susp clunks when making slw turns
I've notice that some times while making slow turns the whole rear of my car kinda vibrates,would this be a differencial issue or something about the suspencion? I do know that there's a leak from the seal that always goes bad (betwen shatf an diff) but the clunk only happens during low speed turns.
thanks for any inputs.
Old Jan 30, 2003 | 05:07 PM
n2ceptor's Avatar
Could be the Limited Slip going out.... Mine did the same thing, but mainly when backing up and turning slow at the same time..
93Z Will
Old Jan 30, 2003 | 05:14 PM
94formulaNYC's Avatar
Mine is having the same problem and its been getting worse. How much does this cost to repair?
Old Jan 30, 2003 | 05:22 PM
95 Z/28 LT1's Avatar
Super Moderator
If I were you guys I would change the rear-end lube and put some GM brand limited slip additive in it. Then see how it acts.
The additive is a friction modifier, and is supposed to let the clutchs in the carrier slip easier around corners, because thats when the rear-end unlocks. (You know, one wheel turns slower than the other).
Anyways, the clutches will last longer with the additive, so it's a good and cheap way of seeing if the carrier is going bad.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
