Help, Car Running, Surging other Problems
Old Jan 30, 2003 | 12:50 PM
96ZRDR's Avatar
Please help!!!
Need Input.
This past Tuesday, I got my car running, but there are a few problems.
1.) The car would not keep running if i let go the gas pedal. So what we did is we adjusted the trottle stop screw in the Throttle body, and mechanically acclerated the car a little. This fixed it, yet it still hunts for idle for a bit, then it settles down. I asked PCM4Less to program the car for a 1,000rpm idle.
2.) In gear, the car surges quite a bit, it wants to take off on its own will.
3.) The Transmission shifts fine but it takes a long time to shift in 4th when I ask it to. I drive on 3 at lower speeds below 55mph. Although I have been hesitant to smash the pedal, it almost seems that the car hesitates to downshift, unless I manually move the lever to the gear I want. Could this be the cause of an unadjusted TV cable?
4.) Also could you please describe the feeling of having a 2800stall, this is my first time driving a stalled car, all my cars have manuals. It seems that the car is hesitant to downshift unless I smash the pedal or manually move the lever. Seems to hesitate under 2800 rpm, but it is not ignition related because the engine revs smooth as hell, and pulls strong.
I am frustrated because I do not know what is suppose to be normal anymore.
Also the car spins tires like crazy if I hit it beyond the 2800stall rpm speed. I am waithing for my drag racing rims to fit to my ET STreet's.
5.) And lastly, not to sound like a moron, but how in the world do you check an auto fluid level? 700r4 has a capacity of 9 qts right?
I checked while at idle after driving a bit, check the dipstick and it was in the hot crosshatched area of the stick, this means it is OK? Right.
Thanks Guys!!!!!!!!
Old Jan 30, 2003 | 03:53 PM
joeSS97's Avatar
As for checking your trans level,do it when it is warmed up on a level surface.The rest I cant help you with,sorry.Heres a TTT 4 ya.
Old Jan 30, 2003 | 04:14 PM
Gripenfelter's Avatar
Could be a bad IAC motor.
Make sure its plugged in snug.
Or swap in someone else's.
Noenav
Mar 1, 2019 07:38 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
