went to tirerack.com...OMG help me...
Old Jan 29, 2003 | 11:30 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
k i put in all my info at tirerack.com and it says stock equipment - 235's optional stock equipment - 245's.... i KNOW i have the stock 5 straight spoke rims... but what size are they? cause the itres i have on now are VR 255's... 50 16.... ummm? what do i do?
Old Jan 29, 2003 | 11:37 PM
wigsredta's Avatar
The 235/55-16 was the standard tire. 245/50-16 tires will fit just fine. It was a performance option from the factory.
Umbrae's Avatar
235/55/16 is standard
245/50/16 was the optional speed rated tire
Your rim size is 16x8
The tire you have on your car now should fit without a problem. So you can replace it with the exact same tire (255/50/16. I'd stick to the 245/50/16 on the stock rim though. Get yourself some Kuhmo Ecsta tires, they seem to be a great tire for the price. Anything will fit and work properly with your speedo though as long as its 255 or 245/50/16
Old Jan 29, 2003 | 11:39 PM
frmula1's Avatar
the 255's have 20 grand on em and they are working fine... and i want the widest tire possible... can't i just stick with 255?
Old Jan 29, 2003 | 11:40 PM
wigsredta's Avatar
I've got the Kuhmo Ecsta's in the 245 size. I like them a lot. Great tire for the price.
Old Jan 30, 2003 | 12:21 AM
TMDZ28's Avatar
Question
what about 255/55/16...will this tire fit on salad shooters?? because i have 215/60/16.......and i want my rear and front tire to be close in height....
Old Jan 30, 2003 | 12:51 AM
Compstall's Avatar
I have the Kumho 255/50/16's on a set of salad shooters in my garage. They fit just fine. The width difference is barely noticeable.
- Brent
Old Jan 30, 2003 | 12:52 AM
frmula1's Avatar
salad shooter = the straight 5 spoke optional rims?
Old Jan 30, 2003 | 12:59 AM
Compstall's Avatar
yep, the stockers.
- Brent
Old Jan 30, 2003 | 01:53 AM
Indy93Z28's Avatar
The salad shooter is not the straight five spoke!
The five spokes were on '97 up cars... salad shooters were '93-96
Old Jan 30, 2003 | 02:39 AM
chesee48's Avatar
that would be correct
Old Jan 30, 2003 | 02:41 AM
Compstall's Avatar
salad shooters, turbine, straight five spoke, whatever you wanna call 'em, they are 16x8 and they all fit the same. so there!
Old Jan 30, 2003 | 01:05 PM
frmula1's Avatar
we can't be talking about the same thing cause my rims are the stock ones and i have a 95... with straight 5 spoke alum. rims... with the abs cap in the middle....
Old Jan 30, 2003 | 02:41 PM
Compstall's Avatar
Yes, even though they don't LOOK the same as mine, they still fit the same. The 255's ARE JUST FINE. THEY WILL FIT YOUR WHEELS.
Old Jan 30, 2003 | 07:25 PM
Indy93Z28's Avatar
That's cause you got a firebird or TA then.
We were arguing about Z28 wheels for some reason... our bad.
