At what point are larger injectors a good idea?
Old Jan 29, 2003 | 04:55 PM
CARGASM's Avatar
Just what the subject asks.
Also, if the injectors are upped to something similier to a 30lb SVO, is it neccesary to upgrade the fuel pump?
Thans, Adam
Old Jan 29, 2003 | 05:01 PM
Trans AM 22502's Avatar
Bigger injectors are typically needed when you're doing a drastic rebuild such as a 383 stroker or a focred induction application (supercharger/turbo)
Other than that, I don't see a need to.
As faras the fuel pump is concerned I would imagine so but I'm not sure.
Old Jan 29, 2003 | 08:32 PM
AlexA's Avatar
They are needed when the duty cycle of your stock injectors pass 90-95%. You can "cheat" and increase fuel pressuer to make them act bigger, but this will only go so far. It is also a good idea to get bigger injectors when doing a dry nitrous kit as the stock ones are prone to locking up.
Bigger injectors are a must for stroker and supercharger build ups.
Use software like DataMaster to measure your duty cycle at WOT. Pay attention to higher RPMs where the window for fuel injection shrinks (6000rpm = 20ms window).
-Alex
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Dec 23, 2014 07:52 AM
Manaz101
Aug 26, 2002 04:26 PM
Pandamonkey
Aug 23, 2002 12:02 PM
