Paging shoebox,nighttrain66, or head expert...
Old Jan 28, 2003 | 07:29 PM
Trans AM 22502's Avatar
I discovered that the banjo bolt hole on the head is ROTTED/CORRODED. I had a board member put the heads back on, intake back on, rocker arms, etc. etc. etc. etc. etc.
NOW, he said I have 2 choices:
Pay $100 for new gaskets and ahve the motor torn apart AGAIN OR
Find a helicoil insert/time sert for the banjo bolt.
GM ****ed up royally by making 18 threads on a 1/2" bolt, which USUALLY has 20tpi on it.
So now what can I do. I don't want to go to every machine shop in town KNOWING that they don't have this helicoil/time sert that fits that banjo bolt.
Another guy at a machine shop said that I coulld weld the hole shut on the head, buy a tap drill, buy a custom tap (1/2" bolt, 18tpi) and drill a new hole in the head, and then put the bolt back in without a helicoil. (as I won't need it anyway in that case)
The problem with this method is that I don't think the dealer has a portable welder on hand to weld the hole shut with the heads on the vehicle, which clearly means Imy only option is to spend $100 I don't have and buy new gaskets.
Do I have ANY other options?
Old Jan 28, 2003 | 07:53 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Paging shoebox,nighttrain66, or head expert...
Save $100?
Old Jan 28, 2003 | 08:09 PM
You can't reuse head /intake gaskets.
Old Jan 28, 2003 | 08:20 PM
treyZ28's Avatar
Beleive me i know
the heads are coming offmy car for the 3rd time now
Old Jan 28, 2003 | 09:52 PM
Never heard of anyone with this kind of problem before. If you cannot find a heli coil or time sert, maybe there is some kind of adapter fitting that could be used. It will probably be a difficult search to find what you need. Pulling the head, welding and retapping is a solution and may ultimately be the easiest in the long run.
DirtyDaveW
Dec 1, 2016 05:37 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
