Valve Cover Gasket Replacement
Old Jan 28, 2003 | 03:05 PM
TobyZ28's Avatar
I'm going to be replacing my valve cover gaskets (old ones are leaking a tad). I've never messed with this part of the engine before, so im a bit neverous as what to do. Anything I need to know taking the covers off? My car is a 95z28 with AC too so from the looks of it its going to be a bit tight.
Also when im under there, what kind of cleaning can/should I do to the rockers and springs? Any help will do plz feel free to talk to me like ima noob.. cuz i am lol
THnx
Old Jan 28, 2003 | 05:08 PM
DaveW 396ci's Avatar
Just pop the 4 bolts out per valve cover and replace the gaskets. Clean the gasket channels in the valve covers off with a paper towel and put the new gaskets in there. Put the cover back on and bold down. The torque spec on the VC is very light. Don't over toque.
DaveW
Old Jan 28, 2003 | 06:09 PM
bad95z28's Avatar
its easy. you'll be suprised how easy it was when you finish. you may have to remove the alternator on the passenger side if you want to remove the valve cover completely.
Old Jan 28, 2003 | 06:13 PM
I think I usually have to remove my AIR diverter fittings, too.
Old Jan 28, 2003 | 09:35 PM
Z28ROC's Avatar
The factory valve cover gaskets, are nice, thick, quality gaskets. Unless the covers have been off and one of them got torn. I cant see them going bad and leaking.
Did you try to snug up the bolts a bit? and are you sure it's the VCs that are leaking and not the intake manifold.
If you do decide to replace them. I'd relace them with factory gaskets.
Also, don't mess with the rocker arms or springs. They don't need any cleaning.
Old Jan 29, 2003 | 06:49 AM
TobyZ28's Avatar
Yea quite sure the leak is there, I tightened them up a bit in the past and its gone away, i just want to clean it up a bit and do it over again. The gasket i got seemed to be of high quality and is a nice thick rubber, but i suppose the GM gasket would be a good idea anyhow. So no cleaning on the thinggymaggys eh? well thats good to hear
Thanks for the replys...
Old Jan 29, 2003 | 08:09 PM
Z28ROC's Avatar
Oh, if you already have some good gaskets. I'd just go with those then.
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Snoman73
Nov 17, 2014 07:22 PM
