Can anyone explain this? (coolant)
Old Jan 28, 2003 | 12:07 PM
JZ28T's Avatar
Question Can anyone explain this? (coolant)
Ok the other day I was letting my car warm up when I smelled antifreeze. I looked under the hood and antifreeze was on top of my intake elbow since then I haven't seen any more antifreeze but sometimes I can smell it. My car doesn't overheat, but the gadge goes up and down alot. It will go up to *210 then back down to *180. Before this it always stayed at *180. Well last night night my low coolant light came on and I had to add some (still I can't find a leak). I am gonna take it to be looked at, but thought I'd post here for some thoughts.
Old Jan 28, 2003 | 12:15 PM
Fuels94TA's Avatar
Squeeze around the hoses were your coolant travels, look for cracks or splits. Maybe under perssure your loosing coolant. If not then look at the weep hole on the water pump to see if any is coming out there. The only way you have coolant at the elbow is the belt is throwing coolant around the engine bay.
Vinny
Old Jan 28, 2003 | 12:32 PM
I agree with Vinny. The water pump likes to leak out of the weep hole and after you shut if off, it will drip right on the crank pulley. Then when you start your car the next time, it will sling the coolant and you might even hear the belt screech for a for a few seconds.
Of course, you could have a pinhole leak that is squirting coolant almost anywhere.
Old Jan 28, 2003 | 12:47 PM
drop top steve's Avatar
Re: Can anyone explain this? (coolant)
I had a similar problem, turned out to be the bottom of the TB. TB bypass fixed that.
Old Jan 28, 2003 | 02:17 PM
93ZM6Tally's Avatar
Bleeder Valves?
Old Jan 28, 2003 | 02:38 PM
shocktrp's Avatar
Maybe you need a new radiator cap?
Old Jan 28, 2003 | 03:00 PM
JZ28T's Avatar
The radiator cap and bleeder valves are clean no leaks there. I give up. I'll just take it to a radiator shop.
Old Jan 28, 2003 | 03:54 PM
pearlpurple's Avatar
Maybe your thermostat stuck closed and then engine got a bit hot and spewed some collant??
Maybe your temp going up and down is the thermo still a bit sticky or your coolaing system now has some air in from what ever caused the first thing.
I would check all of the hoses very carefully, fill my coolant resovoir to the proper point, pop the rad cap add what ever it will take then bleed the system as per proper procedure being careful not to get coolant on the opti.
You do not want to over heat the engine as warped heads can be a result.
Old Jan 28, 2003 | 04:13 PM
joeSS97's Avatar
Unhappy
My vote is for the water pump.
Old Jan 28, 2003 | 04:16 PM
JZ28T's Avatar
I think I will replace the thermostat since it's not a big deal then have the water pump checked. Thanks for the help guys.
Old Jan 29, 2003 | 08:32 AM
JZ28T's Avatar
Ok the water pump just started squealing, so I guess that answers that question. Thanks again guys.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
