Car is cutting out bad under load. . .
Old Jan 28, 2003 | 10:41 AM
TransAmTONY's Avatar
Question Car is cutting out bad under load. . .
ok, here is the situation. My car is running rich about 14.1 :1 to be exact. i was throwing a p0100 code but I replaced my GMS MAF with the stock MAF and I am still running rich.. so... I can put it in neuatral and rev it all the way up with no stumbles or misses... but when I am on the roas and I get on it, once it hits about 4k it misses and stumblws REALLY bad. I have an autotap, so what should I look at to try and diagnose this problem?
Thanks alot, Tony
Old Jan 28, 2003 | 10:45 AM
MeanGreen97Z's Avatar
Export the tables into this post.
Old Jan 28, 2003 | 10:53 AM
which tables?
Old Jan 28, 2003 | 07:50 PM
Josh-'04 GTO's Avatar
Stumbles under load are often the plug wires. When is the last time you did plugs/wires?
Old Jan 28, 2003 | 10:20 PM
Z064MULA's Avatar
I had a problem like this once and I replaced the ign. coil and it fixed the problem, may not be the same but it wouldn't hurt to check. (MSD) !
Old Jan 29, 2003 | 06:42 AM
The tables from the autotap. Export the file of say a 30-80mph drive under load.
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
brandboZ28
Jan 31, 2003 06:19 PM
