nitrous cam good or bad
Old Jan 27, 2003 | 10:18 PM
TheZ's Avatar
nitrous cams in jegs
262 .462/.480
268 .477/.490
274 .488/.501
284 .507.525
ok i don't know jack about cams but, i'm building an 383 forge engine
mods
hooker longtubes,cai,borla no cats,100 shot nx <----old engine
new engine will have 3.42 or 3.73 1.6 rr, p+p heads+ old mods
or should i get an cc 306
Old Jan 27, 2003 | 10:49 PM
Kain's Avatar
Those durations are at .006 tappet lift. Normally you see cams at .050 lift.
My CC306 is a 229/245 at .050, and 290/307 at .006.
How much are you going to be spraying on your 383?
If you're going to be spraying a 100-150 shot, go for a XE 230/236 or XE 236/242 on the normal 112 lobe.
If your going to be spraying more, go for the same cams on a 114 lobe. It'll be more efficent with the power adder.
Also it depends on how fast you want to spin the engine.
If you want to spin 6200-6400, get the 230/236.
If you want to spin 6400-6800, get the 236/242.
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Amshnock
14
Jan 18, 2015 11:47 AM
bandit383lt4
Dec 21, 2014 09:12 PM
chuyz28
Nov 25, 2014 11:14 PM
