4.10 or 4.11
Old Jan 27, 2003 | 06:59 PM
BPS's Avatar
BPS
4.10 or 4.11
Been folloewing the rear gear talk for years and am still confised. Can some one enlighten me.
1 - who makes 4.11 gears - where to buy?
2. are 4.11 stronger than 4.10?
3. if the more teeth the weaker the gear then are 3.42's weaker than 4.11 based on the facts below?
3.42s - 41 teeth on ring gear, 12 on pinion
4.11s - 37 teeth on ring gear, 9 on pinion <--
if not why?
Confused in Canada
Old Jan 27, 2003 | 07:18 PM
drop top steve's Avatar
Re: 4.10 or 4.11
if not why?
.Confused in Canada
If you compared the two pinons side by side, the 9 tooth would be a smaller diameter. That is why a two series carrier has the ring gear mount offset father from the pinion, 2.73 has a large pinion diameter
Old Jan 27, 2003 | 07:19 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
What Steve above said.One pertains to Ford and the GM. You can call them what you want. I belive, don't qoute my on this but, GM=4.11's and ford=4.10's. I always called them 4.10's
I just swiched over to a currie 9", and by doing that did not have the option of running 3.73's any more. They are 3.70's now, but I still call them 3.73's. Hope this all makes since???
Of course I could be wrong altogether.
Just my 2 cents.
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
colts0455
Jul 24, 2015 04:51 PM
