Jack points
Old Jan 26, 2003 | 10:56 PM
sandmanljs's Avatar
Jack points
Ok, i know you can jack up the car from the sub-frames(and that pad thing on the front), or SFC's if you have them. There is the rear axel.
But what about if i just wanted to get the front wheels off the ground. I would have to get them off the ground, so ramps are not an option. Can you use the K-member?? Im talking about that skid-plate looking thing infront of the oil pan. Is that ok to lift with so i can get the jack stands under the sub-frames?
Thanks. Gotta put on new brakes soon.
Old Jan 26, 2003 | 11:08 PM
I use the K member. If you want to keep from putting dents in it, use something for a cushion between it and your jack. Just don't use something that will slip.
Old Jan 26, 2003 | 11:36 PM
Laymaster's Avatar
What's the K-Member? Is that the "A-Frame" that holds the wheels there? You could jack the car up by the engine brace? But I prefer to use the "A-Frame" as someone once told me they were called?
Old Jan 27, 2003 | 01:51 AM
AZ2ENVY's Avatar
Thats what i and several other F-Body owners I know use to jack up the front of the car evenly. Works great.
Old Jan 27, 2003 | 08:30 AM
K-member, front sub-frame, front crossmember (official term), engine cradle...all the same thing. The big, honkin' thing that is under the front of the oil pan and the power steering rack is bolted to.
Old Jan 27, 2003 | 08:34 AM
LWillmann's Avatar
Yeah, it's not just big, it's honkin' big!
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
