Walbro 340 install
Old Jan 26, 2003 | 05:48 PM
Gripenfelter's Avatar
Walbro 340 install
What does it take to install this pump in an LT1?
I heard there was a problem with the jet pump that needed to be modified and the wiring?
Will it fit inside the harness or is there a big size difference?
Old Jan 26, 2003 | 08:13 PM
ttt
Old Jan 27, 2003 | 09:49 AM
anyone install this walbro?
Old Jan 27, 2003 | 11:29 AM
GhostZ's Avatar
You don't have to modify any wiring. The pump won't fit inside of the stock...um...whatever the name is. The plastic thing around the pump that keeps fuel to the pump under cornering.
I just removed that plastic piece and zip tied the new pump to the entire housing.
Once you get it out you'll see what I mean. Take off the big cream plastic piece that the old pump sits in and zip tie your new pump to the same location.
Old Jan 27, 2003 | 11:39 AM
So there's no problem with the Jet Pump?
Do you have any problems idling when you get under 1/4 tank?
Old Jan 27, 2003 | 06:57 PM
GhostZ's Avatar
The only idle problems I have is from the cam.
Have fun with the install
Old Jan 27, 2003 | 07:01 PM
96speed's Avatar
Cool
What's a 'Jet Pump?'
Get a Racetronix kit. Excellent support, excellent product, uses the stock fill bucket (no issues with pump starvation). Worth the coin.
Ryan
Old Jan 27, 2003 | 07:25 PM
GhostZ's Avatar
Didn't see that you asked about jet pumps.
See the reply in Adv. Tech.
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
