60-1 turbo specs
Old Jan 26, 2003 | 04:04 PM
Omega's Avatar
60-1 turbo specs
What is the exhaust and compressor a/r for this turbo?
Is the 62-1 much different? What are the specs on that turbo?
I am looking for 450-500 HP out of a 355.
Old Jan 26, 2003 | 09:34 PM
BigDaddy's Avatar
try looking here www.turbonetics.com
Old Jan 26, 2003 | 10:50 PM
Omega's Avatar
That was the first place I looked This is as useful as it gets:
Available with either the standard (4” inlet, 2.5” discharge) compressor housing or the 60-1 Hi-Fi ( 2 3/4” inlet, 2” discharge) compressor housing, the 60-1 will outflow any standard T04B with ease! (The 60-1 Hi-Fi will deliver approximately 90-95% of the flow capacity of the standard 60-1.)
Old Jan 26, 2003 | 11:19 PM
89ProchargedROC's Avatar
Re: 60-1 turbo specs
how good are your heads and how much boost do you plan to run?
you could probably get away with a T04b h-trim turbo which is a 58mm turbo....maxes out right around 550hp or so. Would spool like mad too
My suggestion is to use a 60-1. If you have room, go with the larger compressor housing version (4, 2.5). The hi-fi is just sticking the 60 wheel in a smaller housing for space reasons...it cuts down the airflow about 15%
The 62-1 uses the same compressor housing as the 60-1, just a larger wheel. After that i *believe* you get into the T series housings that are .70a/r on the compressor side are are a tad bigger than the 60a/r compressor housings
hope that clears some things up
Old Feb 5, 2003 | 01:25 PM
Omega's Avatar
The heads I am planning on using are the Sportsman II's. I don't think I will ever go over 10#'s.
I was leaning more towards the 60-1 myself, but I would rather "under run" a turbo than over spool.
The 60-1 comes with the LT1 kit correct? Do many people upgrade from that turbo?
Old Feb 5, 2003 | 06:24 PM
Mikey 97Z M6's Avatar
Here is a link showing comparisons for different turbo sizing etc.. Most of these are used on the Supra's but it's still good info when comparing compressors/turbine sizes.
http://moreboost.org/turbos.htm
Hope that helps,
Mike
Novo
Jun 14, 2016 02:58 AM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
