infamous Low end hesitation problem.. now a dead LT1!!
Old Jan 26, 2003 | 01:16 PM
nB5sP's Avatar
hey guys.. i never had a problem with low end.. even after some mods. but after i had the opti replaced i started having the hesitation at low end problem that so many people on the forum have. but now im wondering if it could be age. cause my '93 LT1 motor blew the other day. i heard a loud backfire.. and then i couldn't restart the engine. i hope you guys could help me figure out a couple things..
1. the low end hesitation.. i changed wires, plugs, fuel filter. and the fuel presure is good. could it be some electrical wiring that's old or the opti again? what about timing?
2. and if my engine acctualy blew or not. cause i'm not sure.
thanks!!!
Old Jan 26, 2003 | 01:45 PM
neil350's Avatar
A bad Opti will throw a DTC 16, scan the computer and make sure. It did on my 93/
Old Jan 26, 2003 | 02:59 PM
nB5sP's Avatar
anyone else? should i do a rebuild?
Old Jan 26, 2003 | 03:24 PM
bad95z28's Avatar
i think you need to figure out what wrong first. check the oil does it have coolant in it? metal shavings? did it spit antifreeze anywhere. i've seen an opti go out and the car will backfire, die , and not restart.
Old Jan 26, 2003 | 03:29 PM
White96Z's Avatar
2. I doubt the motor is blown. When it backfired, how were you driving the car? ie: rpm, speed, throttle on the floor?, etc. Did it shoot any smoke when it backfired?
1. I would put money on a bad opti or bad installation. If you had it done very recently they should fix it for you. If you did it yourself, have fun doing it again. I had the problem and after my opti replacement it was still kind of around. Eventually determined it was the EGR valve, but i don't believe you have one on the '93, which leads me to believe it's the opti again. You've done all the right things, fuel filter, plugs, plug wires. Did the computer throw any codes before it died?
I would check to see if I had spark before I decided to rebuild the engine. That is big conclusion to jump to. You might just have a bad coil, coil wire, ICM or opti.
Old Jan 26, 2003 | 03:41 PM
nB5sP's Avatar
it was in the morning. i was just warming it up. it was hesitating bad and it went 'bang'. i didn't see smoke though.
Old Jan 26, 2003 | 04:55 PM
DjArcadian's Avatar
Possibly they put the spark plug wires on incorrectly causing misfires.
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
