Removing AIR System on 97
Old Jan 26, 2003 | 09:07 AM
00tals1's Avatar
How do I take it all off with out throwing any codes. I want to clean up the engine bay. Thanks for your help.
Old Jan 26, 2003 | 10:42 AM
Hyperspeed97z28's Avatar
Is there any web pages that show the removel step by step?? I'd like to do this as well, I KEEP THROWING THE DAMN FUSES.........
Old Jan 26, 2003 | 10:55 AM
Smokn '94 Z's Avatar
Thumbs up
It is really not that hard if you know what you are looking at. The hard part is getting the damn tubing out of the car whole. I ended up using a small tubing cutter & cut the tubing into 3 peices to get it out. There was a small bracket that held the tubing on under/behind the power steering pump that I could not get off. Then you just have to find something to plug the bungs on the intake manifolds.
Like this... Plugged Exhaust Manifold A.I.R. Bung
Then remove the pump itself & bracket isn't needed either. Then plug the bung on the CAI that the rubber tube is connected to with something. I believe some people have said if they pull the fuse for the A.I.R. pump that they don't get a code. I had mind deleted in programming. It really does clean things up in there.
Good Luck.
Old Jan 26, 2003 | 11:04 AM
What did you use to PLUG the AIR bungs? I cant pull the fuse on my 97 cuz I believe it shares controls with the fans... I can live with the ses light for a while, is there any way to jump it so the pc reads it as still on, I'm gonna do a pcm for less program, but that wont be til I get the headers in and the egr removed as well......
Old Jan 26, 2003 | 11:11 AM
Jackse's Avatar
There is no way to get around the ses light without reprograming the pcm. i jus thad to get mine done so i could pass inspection. obd2 sucks!!!
Old Jan 26, 2003 | 11:18 AM
97FormulaWS-6's Avatar
The 97 Air-Bung threads are 3/4-16 thread plug. You will need to program out the Air system out though, either with LT1 Edit, or an aftermarket mail-order tune.
Old Jan 26, 2003 | 11:22 AM
I used some 3/4 - 16" treaded rod & welded a nut on the ends of the rods then I put it on the lathe at work to make them look nice & Machined... If you want some I can make some up for you at work...
i herd an m22 drain plug ??
Old Jan 26, 2003 | 11:25 AM
Lightbulb
You have stock manifolds? If so I think you might be right?
Old Jan 26, 2003 | 11:58 AM
stock or headers wouldnt they be the same? figuring the stock air tubes connect to headers???
Old Jan 26, 2003 | 12:08 PM
Mikey97Z's Avatar
These big set screws fit, and they look nice too.
http://www.mcmaster.com/param/asp/ps...5=5588;136=977
Go to the Mcmaster.com to order them.
Old Jan 26, 2003 | 01:12 PM
Excellent!!! Ordered a pack! Thanks!!!
Old Jan 28, 2003 | 05:39 PM
Mikey what the hell do those screws fit on? i tried them on my headers and they are to small? do they fit on stock manafolds? i would figure that stock manafolds and headers are the same ?? either way can someone go to http://www.mcmaster.com and help me find the plugs that will fit my dynomax shorties so i can delete the AIR system? thanks.... im HOT about the ones i just bought not fitting...
Old Jan 28, 2003 | 08:45 PM
95 and 97 style air fitting different???/ anyone????????
Old Jan 29, 2003 | 09:53 AM
Mikey97Z's Avatar
Yes, the older ones were different. A 95 prolly uses a M22 metric plug. It's a little bigger than the 3/4" plug. I'm not sure what year they changed. 1996?
