LT1 has no power and makes clacking noise
Old Jan 25, 2003 | 08:14 PM
Ryan's Rod's Avatar
I'm doing a disaterous LT1 4L60E swap into a K5 Blazer and have had nothing but trouble from the setup. I had the engine rebuilt by a machine shop and the transmission is almost new but my problem is that every time I get on the gas, at a certain RPM it makes a loud clacking noise. On top of that, it doesn't seem to have any power. My old 350 with 165 horses did a lot better than what this thing is doing now. Any ideas on what the problem might be? Wiring? A sensor?
Old Jan 25, 2003 | 08:39 PM
ollie-99's Avatar
i'd double check ur plugs and the optispark
it can cause tons of problems
Old Jan 25, 2003 | 08:57 PM
Ryan's Rod's Avatar
plugs are brand new. Opti... I don't even want think about that. That thing was the worst idea in history. I'll replace it if I have to but I think it's somwthing else.
Old Jan 25, 2003 | 08:59 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
sounds like someone has some knock???
is it high rpms?
may be signs of spun bearing(s)
Old Jan 25, 2003 | 09:01 PM
Ryan's Rod's Avatar
On an brand new rebuild????
Old Jan 25, 2003 | 10:22 PM
Mtrhds94Z's Avatar
'clacking' is usually loose valves.. Check those...did you adjust em? rebuilt may not be adjusted correctly...
Old Jan 25, 2003 | 10:30 PM
treyZ28's Avatar
rockers?
hey its definatly possible
1 bad bearing clearance
Old Jan 25, 2003 | 10:45 PM
xxsaint69x's Avatar
maybe u switched few wires around on the opti?? double check that
Old Jan 26, 2003 | 01:21 PM
Ryan's Rod's Avatar
Spark plug wires?
Old Jan 26, 2003 | 01:29 PM
treyZ28's Avatar
Originally posted by Ryan's Rod
Spark plug wires?
yea
Old Jan 26, 2003 | 08:13 PM
Ryan's Rod's Avatar
It's not a constant clacking noise. It's just at a high RPM when I step on it, or even rev it parked. That's the sound, and it doesn't have any power.
Old Jan 26, 2003 | 08:19 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
you didn't put regular in it did you?
Old Jan 26, 2003 | 08:27 PM
Supermanx500's Avatar
I have that same noise and I have no Idea what it is!!!!!!!!!!!!!!!
My power seems to be fine but then again there could have been something wrong the whole time and can't tell there is something wrong....oh ya and the noise seems to move around from left to right from the engine bay
Old Jan 27, 2003 | 11:53 AM
Ryan's Rod's Avatar
Yeah, I did put in regular. Could that be part of the problem?....Or all of the problem?
Old Jan 27, 2003 | 01:02 PM
94 CAMRO Z28's Avatar
I dont know about all of the problem, but im willing to be it could be part of it. My car runs like crap on regular.
Aaron
