AFR Heads and what plugs?
Old Jan 25, 2003 | 06:33 PM
97TA-WS6-Con's Avatar
Those of you running a blown motor with AFR heads. What plugs are you using?
I HAD been using the NGK TR6's on my LT1 heads but AFR says that I need a gasket. The TR6's do NOT have a gasket.
When I bought the heads they came with some NGK plugs that DO have a gasket.
The model number is "BCPR6E - 11" and are *gasp* "for imports"
Can anyone give me some idea if these plugs are the right ones to use, and if not, which ones.
Old Jan 25, 2003 | 08:03 PM
Willie's Avatar
Well, I don't know anything about the plugs you mention, but I use Autolite 3923's with my 190's. They are three ranges colder than the "normal" heat range, a 3926. They seem to work well for me.
Old Jan 26, 2003 | 09:38 PM
Highlander's Avatar
I am using ngk bpr7es which are one range colder plugs...
Old Jan 27, 2003 | 11:24 AM
Camaro_SS/R's Avatar
I have the AFR heads and have been running with the TR6 for 3 years with no problems. ?
cheers
Old Jan 27, 2003 | 08:52 PM
yellow Z28's Avatar
same here, im use the TR6's in my car and they work great, have had alot better luck with these over the autolites
Old Jan 27, 2003 | 11:06 PM
Do you guys running the TR6's have any kind of gasket with them?
NGK sent me an email saying the ones I have would be fine but to gap them to .350 which I was going to do anyway.
Old Jan 28, 2003 | 12:04 AM
yellow Z28's Avatar
nope no gaskets...
Old Jan 28, 2003 | 12:09 PM
no. Don't ever remember seeing a gasket for the TR6 with the AFR heads.
--Hugh
Old Jan 28, 2003 | 02:48 PM
Well it was AFR that said I should have gaskets and they recomended Autolites, but the heads came with these NGK plugs and it looks like they will work.
*shrug*
Thanks for the response guys.
Old Jan 28, 2003 | 05:08 PM
engineermike's Avatar
The AFR heads are machined for a gasket seat plug. The area around the threads is machined flat for the gasket to seat. This is common in aftermarket aluminim heads. I use A/C FR3LS, but the Autolite 3924 / 4 / 5's will work.
The stock heads are machined for taper seat plugs. The area around the threads is machined with a taper for the plug to seal against.
Mike
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
