Shoebox... Need Ur Help With This...
Old Jan 25, 2003 | 01:58 PM
Hyperspeed97z28's Avatar
on the left side of the TB, theres the hose that goes from the TB to the pass side Valve cover, under that hose there is a rubber elbow that connects to a plastic line, what is that rubber elbow with 2 different ends and perhaps you know the part #, mine has a crack in it, I wrapped it with elec tape for now, but I prefere to replace it, I appericate your help and I figured if anyone knows what it is, YOU THE MAN!!! Thanks bro....
Old Jan 25, 2003 | 02:13 PM
Mtrhds94Z's Avatar
Pretty sure this is it.. goes to the 'canister purge solenoid'
It's a small plastic line with a rubber elbow on one end and a straight one on the other.. about 5 bux from Jason Cromer..
Evap Canister Purge Solenoid Pipe p/n 10105324
# 5 in shoebox's pic here:
http://csce.uark.edu/~jgbertr/rb/1995_evap.jpg
Old Jan 25, 2003 | 02:34 PM
If it is item 5 on this diagram, Charlie gave you the right part #.
Old Jan 25, 2003 | 02:41 PM
Thumbs up
Thanks guys, that is the right part! THANK YOU!!!
Magenta_Hearts
Mar 25, 2015 10:24 AM
madwolf
Sep 19, 2003 02:14 PM
1995greenTA
Sep 14, 2003 05:14 PM
JasonD
Jul 15, 2002 02:17 PM
