Want to run in the 10's all motor on pump gas.........
Old Jan 25, 2003 | 07:42 AM
FASTFATBOY's Avatar
What's it gonna take? I have a 9 inch in the car already, hooker longtubes and 4" Mufflex also on the way, built 4L60E on the way with Yank converter. I figure I need close to 600 Flywheel HP, 450/460 at the tire, car will weigh 3600 with driver. Suggestions?
David
Old Jan 25, 2003 | 09:37 AM
red's Avatar
red
A lot of motor and a well thought out suspension. With my set up I have run 121 MPH on pump gas. Once I get the suspension worked out this winter I am hoping to get the 60' low enough to get me that 10 I have been looking for.
Old Jan 25, 2003 | 09:49 AM
BigDaddy's Avatar
I want a cheeseburger and fries, but it's 10:48am and they don't start making lunch till 11:00am. Oh well.
Old Jan 25, 2003 | 09:51 AM
FASTFATBOY's Avatar
Well if you really WANTED a cheesebuger and fries before 11, you could find a way to do it, it has been done. LMAO
David
Old Jan 25, 2003 | 10:00 AM
bad95z28's Avatar
Old Jan 25, 2003 | 10:40 AM
95_RipperZ's Avatar
Check out Jordan Musser's car. www.fastblackcar.com
Also, curious as to why you say in your post that you have a stall when in your sig it says you have a M6?
You are gonna need to have some awesome flowing heads. That is where all the power is.
Old Jan 25, 2003 | 01:57 PM
4drLT4's Avatar
Go here for 10's on the motor...
http://www.race-prep.com
Old Jan 25, 2003 | 07:51 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
A nice 396 Solid Roller setup, with wicked heads should do the trick. Good luck
Old Jan 25, 2003 | 08:23 PM
FASTFATBOY's Avatar
Well the plan is a solid roller 383, heads that flow 315@.600, lt4 intake, 12 to 1 compression, 58 MM TB, 36 lb inj. , 4" mufflex, Hooker LT's, 4L60E with yank converter, 9 inch and 4.11 gear. and some GOOD suspension.
David
Old Jan 25, 2003 | 09:54 PM
PNYKILR's Avatar
That should do the trick then. Your on the right track here, and should acomplish your goals.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
