Do I have to plug the Water pump gear hole for Meziere install??
Old Jan 25, 2003 | 01:16 AM
Trans-Am's Avatar
I put in the meziere and I took out the water pump gear drive and bearing. Is it really necessary to plug up that hole with a plug?? thanks~~rob
Old Jan 25, 2003 | 07:07 AM
Ken95Z28's Avatar
No, It's not necessary.
Old Jan 25, 2003 | 07:27 AM
Frank95z's Avatar
If you removed the drive that is located under the timing cover I believe that you do need to plug the hole. If you just removed the spline that connects the the drive under the cover to the rear of the old waterpump, no the seal will keep it from leaking. Hope this didn't confuse you. Frank95z
Old Jan 25, 2003 | 07:38 AM
Ken95Z28's Avatar
Frank, I think he is talking about this hole
Water Pump Hole
The big round hole. I plugged mine just because I'm ****.
Or you can look at this site that I created....
CSI Install
Old Jan 25, 2003 | 10:07 AM
bad95z28's Avatar
i've heard of people just using a quarter and some rtv on the timing cover water pump hole if you remove the drive.
Old Jan 26, 2003 | 12:30 AM
Trans-Am's Avatar
Cool, I might just throw a freeze plug in the block just to be safe. Although I dont think its necessary to. thanks for your opinions.~~~rob
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
