HOTCAM or LS6 CAM bigger?
Old Jan 25, 2003 | 12:04 AM
therealmagyver's Avatar
It's probably something I can find myself, but I am too lazy tonight to find out the info. Plus I figured yall will give me other feedback on which one to get. I already ordered my QTPs LTs, so the next step is the cam.
Old Jan 25, 2003 | 12:48 AM
stik6shift98's Avatar
hotcam...but dont get it.....
id get a comp or thunder racing
Old Jan 25, 2003 | 12:50 AM
35thanniv.SS's Avatar
Im pretty sure the LS6 cam has a bigger lift, but the hot cam is more aggresive. Also it's a lot cheaper then buying other cams. BTW im selling my LS1 Hotcam kit if your interested.
Old Jan 25, 2003 | 01:16 AM
02 ls6 has bigger lift but 01 should be the same
hotcam is a lil more aggresivve but u should definelty get thunder or comp for optimum performance
ls6 has like no duration
you need extra lift if u have heads
Old Jan 25, 2003 | 02:29 PM
OK cool. I found the following info below. Ok so you guys suggest comp cams or thunder racing. Keep in mind I don't want something too radical. The z06 sounds pretty tamed and thats what I want. I use my z28 pretty often, even though I have a second car...so basically I need it to be good for a daily driver. I want the extra punch at the track or occasional highway race. I won't be doing the heads, so with this info in mind what do you suggest?
Hot Pick: LS1 Hotcam Camshaft (Duration @ .050: 218 Intake / 227 Exhaust) (.525/.525 Lift) / 112 LSA: $375.00.
Hot Pick: ASA Hotcam Camshaft (Duration @ .050: 226 Intake / 236 Exhaust) (.525/.525 Lift) / 110 LSA: $400.00.
2001 LS6 Cam: 204/211 .525/.525 Int CL:118, Exh CL:114 LSA:116 Cam Base Circle: 19.3mm
2002 LS6 Cam: 204/218 .551/.547 Int CL:120, Exh CL:115 LSA:117.5 Cam Base Circle: 19mm
Old Jan 25, 2003 | 02:44 PM
ratio411's Avatar
Use the 02 LS6 cam. Decent power (for a daily driver), decent price, easy on parts...
The Hotcam is cool, but it idles hard.
The more aggressive cams like TR and Comp cost ALOT more and only make slightly better power from the dynos I have seen. TR 224 only got 9 hp more in the same engine, no other changes.
Dave
HarleyZ28
Oct 5, 2015 06:23 AM
k1996z28
Apr 13, 2015 06:54 PM
thenewkid
Apr 12, 2015 07:42 PM
InfernalVortex
Jan 17, 2015 09:35 AM
WildRidez
Jan 16, 2015 03:10 PM
