system cut out
Old Jan 23, 2003 | 09:46 PM
94ZRiCeKiLr's Avatar
system cut out
whats up all im new to this section and i got a problem.....
when i got my car it had a simple system in it consisting of an alpine 45 watt x 4 single cd head unit, stock speakers (i think theyre stock) a 600 watt kenwood amp and a single 12" legacy sub. some time after i got my car i just noticed that my sub had stopped working. it wasnt sudden like it cut out it was just one day i noticed it wasn't making bass. I checked the amp fuse, the connections to the sub and the hot wires running into the amp to see if it was getting power into it as well as all the ground wires i could find. all turned up ok. the only things that make sense to me at this point are either the amp isnt working or the sub kicked the can. it doesnt seem to make any sense that this would happen since i never cranked anything anywhere near its limit. the sub handles 1000 watts so the amp shouldnt have been able to blow IT. could the problem be the amp?????could i need to replace the whole thing????? if so y would this happen out of nowhere like this.
Old Jan 25, 2003 | 07:44 AM
PaulN64's Avatar
I would try hooking up another sub or speaker to it and see if it gets a signal. If it does get a signal, then you sub has probably had it. If it doesn't, then check your RCA's and make sure that they are plugged in properly. If the RCA's are fine, then you want to think about trying another set of RCA's. Also, I'm not sure if the amp is a 2 channel or mono, but if it's a 2 channel, tryin using only one channel. Your amp may have a blown channel. That's all I can think of right now. Good luck and let us know how it turns out.
Old Jan 26, 2003 | 04:09 PM
stik6shift98's Avatar
ya id try hooking up another sub.....
try getting new wires to the sub as well maybe their cut somewhere......
maybe thers a problem inside your box a wire came loose or soemthing......
Old Jan 26, 2003 | 11:57 PM
doyouwannaride's Avatar
tool needed:
a c battery
a digital multimeter
hook up the speaker wires to the battery just to make sure that it is accepting the current. It will make cracking noises if so then go to the amp
use your mulitmeter and check the connections comming out of the speaker spot to make sure that there is a signal coming out.
Old Jan 29, 2003 | 10:05 PM
Shawnster95Z28's Avatar
SEE ALL OF THE ABOVE!!!!
Old Jan 29, 2003 | 11:47 PM
x7x7's Avatar
does the amp come on (does the light come on?)? If not check the remote and ground wire and double check fuses.
Old Jan 29, 2003 | 11:58 PM
Raph8erxxx's Avatar
If you smell the sub Back by the magnet and connections and it smells a little burnt you blew the speaker. Just a quick way that works alot of the time.
Old Feb 2, 2003 | 08:25 PM
well its been awhile but i finally figured it out....i had a blown fuse under the hodd which i forgot to check...replaced and the stereo immediately blew it again...somewhere theres a hot wire scraping a grounded part of the car or something, i cant find it but im taking the car in tomm to be rewired anyway, have to get rid of that damn barrel shaped sub box my sub is in now....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Collector Car
Jan 5, 2015 10:58 AM
