Is this bad?
Old Jan 22, 2003 | 09:50 PM
Black01_Z's Avatar
Is this bad?
I was working on the car and disconnected the IAT. When I was done, I forgot to reconect it. Well aparently I was driving it and while driving it must have scraped against the engine belt and was damaged. Well I tried to reconect it but it is too damaged to fit. Can I drive w/o it? How much is a replacement and where can I get one?
Old Jan 22, 2003 | 09:51 PM
jd13's Avatar
You can drive around without as needed, but I wouldn't do too much driving. Get it replaced so you don't cause anymore problems.
BlackRocketZ's Avatar
Should be able to get one at GM or a wrecking yard.
Old Jan 22, 2003 | 10:09 PM
Black01_Z's Avatar
how much? and what are my chance of having a problem till I get it replaced?
Also if a moderator sees this, I think i should have posted in a tech forum.
Old Jan 22, 2003 | 10:14 PM
Shockwave's Avatar
Lounge Moderator
Moving to LS1 Tech...
Old Jan 22, 2003 | 10:37 PM
nikkev's Avatar
The part is only like $14 at GM.You should get it taken care of ASAP.Your engine will probably be in "loop" mode until the computer acn figure out what the intake air temp is at.I could be wrong,but I "think" that's what happens.Anybody care to correct me?
Kevin
Old Jan 22, 2003 | 11:17 PM
Black01_Z's Avatar
What is loop mode and does it go away when u get a new IAT?
Old Jan 23, 2003 | 04:46 PM
Black01_Z's Avatar
Now my Low Oil light came on, is this related to the IAT being broken?
Old Jan 23, 2003 | 04:56 PM
XKnightRider's Avatar
Doubtful, better pull that dipstick and check that oil !
Old Jan 23, 2003 | 09:56 PM
Black01_Z's Avatar
Got the new IAT, put it in. No problems. Yup time for more oil.
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
