estimated 1/4
Old Jan 21, 2003 | 07:29 PM
CamaroRSguy's Avatar
estimated 1/4
I'm pretty bored right now, so I was thinking about my car and what my mods will give me. So what 1/4 mile time do you guys think my exhaust, intake, Cam (L36 Lobe Specs
206 degree/212 degree at .050
Intake Lift .320 (.512 lift at 1.6:1 rocker ratio)
Exhaust Lift .325 (.520 lift at 1.6:1 rocker ratio)
113 Lobe Separation) unless you suggest a different one, chip, 3.42's, and pacesetter headers will give me?
Any suggestions?
THanks
Old Jan 22, 2003 | 12:14 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
thats a pretty mild cam
mine for my 3.4L is 240/214
lift of .423 with 1.5ratio rockers
and a lobe seperation of 109 degrees
im not too sure about other cams for your engine, but im sure there are a lot hotter ones , but that might not be a good route if you arent wanting to do anything to the heads
Old Jan 22, 2003 | 10:01 AM
2turboz28's Avatar
the cam in my 3.4 is designed for a turbo and its alot higher lift and a little more duration. if your going to go n/a, then i suggest a bigger cam. tiago told me that u can run up too a .550 lift on a stock bottom end without any clearence probs!!!
Old Jan 22, 2003 | 03:01 PM
From what I've heard, doing the heads ( port and polish and 3 degree angle job) doesn't do much for the price on my 3.8's (correct me if im wrong please). So I was trying to keep the price down. Im just looking for get into 14.7-14.8 and trying to figure out how to get there without nitrious. Thanks.
Old Jan 22, 2003 | 03:12 PM
Wolfie's Avatar
stock 3.8 heads flow bad above .500 lift, I'd get a smaller cam than that unless ya get headwork done
Old Jan 23, 2003 | 11:19 AM
CamaroFrk2002's Avatar
That might put you into the high-14 range
Old Jan 26, 2003 | 02:43 AM
chesee48's Avatar
u think so?
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
leftclixLS3
Sep 17, 2015 03:12 PM
