T56 Transmission Troubles?
Old Oct 27, 2009 | 11:00 PM
SuperSport346's Avatar
I have a 2002 SS with 28k miles. For a couple months, the transmission would slip out of third, and a couple times it would get stuck in fourth gear. We ended up tearing the transmission apart, and found it was the 3-4 synchronizer keys were broken. We then found the 5-6 shiift rail was bent as well, so that needed to be replaced.
So I was wondering if anyone else had this problem, because I hear it's a common problem, and I want to complain to GM and see if I can get some of my money back. Thanks for any help!
By the way, thegearbox.org is a great site for transmission parts, and saved me a few hundred dollars, and I recommend checking them out if you need some T5 or T56 parts.
Old Oct 28, 2009 | 01:19 AM
gregrob's Avatar
Yeah, its common if you flog it. Drivin like a granny it probly would never be an issue.
Good luck on the money back thing..
Old Oct 28, 2009 | 06:40 AM
AL SS590 M6's Avatar
Moderator
The only way that these things happen is if you beat on the car and GM is not going to pay for abusive damage on a 8 year old car.
And this is NOT an engine tech question so I'll move it to drivetrain where it belongs.
Old Oct 28, 2009 | 09:01 AM
I wondered about that...how do I move it? EDIT: Thanks to whoever moved it!
And I haven't abused the car. I bought it with 15k, so I don't know what the previous owner did, but the clutch had very little wear, so I don't think it was abused.
Old Oct 28, 2009 | 09:05 AM
jsetzer's Avatar
Common if its beat on, or someone is real hard on the shifter. Mine did the same thing.
If it was having 3-4 problems I would replace that fork with a steel one while you are at it. Very common for those to bend too.
A good shifter with stops in it will help. Or if you can find another creative way to keep the forks from over extending.
Old Oct 28, 2009 | 12:29 PM
gregrob's Avatar
02's had a steel fork already IIRC
Old Oct 28, 2009 | 12:41 PM
JakeRobb's Avatar
Super Moderator
Mine didn't (but does now).
Old Oct 29, 2009 | 01:38 AM
gregrob's Avatar
Strange, I thought all 01+ T-56's had the steel fork.
Pretty sure at least the vettes do
Old Oct 29, 2009 | 09:42 AM
Mine had an aluminum fork, and yes I did put a steel one in. I also bought billet keys so they won't break again, like those cheap stamped steel ones did.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Devinfoote87
Parts Wanted
Apr 14, 2015 04:29 PM
cmdeshon
Jan 4, 2015 11:15 AM
Desolate_Flux
Aug 10, 2002 01:08 PM
