wire schematic
Old Jan 21, 2003 | 05:09 PM
WICKED67's Avatar
Question wire schematic
My dad has a 67 camaro and he is putting a 69 camaro steering column in it. The problem is the wiring is somewhat different. If you know where I can get an online wiring schematic for a 67 steering column that would help out alot. I've searched and just can't seem to find anything. If you can help out in anyway just post it here.
Thanks,
Nicholas
Old Jan 21, 2003 | 05:30 PM
roadblock's Avatar
There is little that will interchange on the two. The ignition lock on the '67 is on the dash and the '69 has it on the column.
Old Jan 21, 2003 | 06:34 PM
texlurch's Avatar
Actually, the wiring for the horn, turn signals, and emergency flashers should be the same size and color code. You will need to reroute the wires from the stock ignition switch to the column if you want to use the switch in the column.
I have an old, Chiltons hard back manual, and it has all the schematics in it.. you might check the local library
Old Jan 22, 2003 | 10:13 AM
WICKED67's Avatar
Thanks guys, Maybe I needed to give a little more info. There is not a stitch of wiring in the car right know and he has a painless wiring kit for a 67. The plugs are different on the columns. I will get some more info from my dad this evening. I was really just wanting to know if there was some place online that I could just get it for free. El Cheepo is my moto.
Old Jan 22, 2003 | 01:10 PM
68SuperRam's Avatar
If you already purchased a kit for a 67, just contact painless wiring and ask them for the information that you are looking for regarding the wiring of a 69 column. They should help you out - without any problem, since you purchased a kit from them.
Old Jan 24, 2003 | 02:13 PM
yzguy's Avatar
yeah and if you ask them nice they might even send you the plugs... or at very least I'm sure you could buy them...
Apr 27, 2015 06:08 AM
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
