Why can't I check my codes on my LT1
Old Oct 24, 2009 | 09:25 PM
camarowayne's Avatar
I have a 94 camaro with a motor out of a 95 impala ss, that was hand built with a lot of goodies in it. I had opti spark problems but msd solved the problem now Im having problems checking the codes on my car why is this happening.
Old Oct 24, 2009 | 11:16 PM
What are you using to check the codes? Need more info.
If you are trying to flash them on the dash, it won't work. You need a scanner.
Old Jun 9, 2010 | 11:11 PM
Engine Codes
I understand that i need a scanner but is there any particular type of scanner that I need to use, because I have a 94 Camaro with a 96 computer and the computer has been programmed for the mods on the engine.
Old Jun 10, 2010 | 05:14 AM
Lets make sure this info is accurate:
You have a 94 F-Body chassis.
You have a 95 B-Body LT1 engine
Tou have a 96 ????? PCM (probably would have been a good idea to include this in the first post)
If that is correct:
The 94 chassis would have a 12-pin OBD-I ALDL connector. The 96 PCM (whatever its out of) would be OBD-II. Have you wired the PCM correctly to a 16-pin OBD-II ALDL connector? Are you trying to scan it with an OBD-II scanner?
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
