need help finding my problem..WOT misfire..anyone around that can help?good with LT-1
posted in the LT1 Tech..but need someone around that might have a garage and or know what to track down in the Z's problem area..just hit 80K...and now at WOT it missfires and very slightly idles rough..need some help and more than anything warm place to figure this out..I have a place if its needed but no tools or diagnostic equipment..
thanks guys!
thanks guys!
Without a formal diagnosis, I would change out the coil and coil wire long before the opti. Stock coils typically only last 60-80,000 before they go bad and they are pretty cheap and quick to replace compared to the opti.
I really don't think it makes much difference. coil doesn't really help performance until you start pushing some serious horsepower. However, if you are going with an aftermarket ignition, I would normally recommend staying with the same brand for all of the components. It makes troubleshooting and support much easier that way.
Everybody has a favorite, MSD, Crane, whoever... I happen to have a MSD coil and a MSD 6AL. It has worked flawlessly for two years. I can't say it has done anything for me performance wise however.
Originally posted by Caps94ZODG
should I get a MSD blaster coil just for the upgrade to them and going to be adding the other stuff soon..or should I wait?
Like Tnthub said, stick with the same brand for ignition components. For instance I have all MSD stuff on my car and I'm pretty happy with it.
Good luck
Sergio
Jan 27, 2016 04:27 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
