car is running
Old Sep 28, 2009 | 06:27 PM
zl1dreams's Avatar
car is running
hey guys i finally got my car running. i just had the dual fuel pumps installed with the 2nd pump running off a hobbs switch. car fired right away.
but now... when i turn the key to the on position im getting very little pressure....i try to turn it over and it cranks fine but wont start for a good 5 - 10 seconds, then its back fires a few times before she idles smooth. i am open headers though right now.
and once idling, the fuel pressure is at #44psi with the vacuunm line off the AFPR. and once shees warmed up, she starts right away.
any thoughts guys, i did a search but found no real answers.
Old Sep 28, 2009 | 06:36 PM
boosted-lt1's Avatar
Tells me that the FPR is not working correctly.
Old Sep 28, 2009 | 06:40 PM
zl1dreams's Avatar
its a brand new one from aeromotive. is there any way i can check to see if thats the problem
Old Sep 28, 2009 | 06:53 PM
Could you put the stocker back in and see if it primes properly?
Not sure if that's the quickest way to tell... Maybe others can chime in.
I assume you have an in car fuel pressure gauge. What does it read when you prime the pump? If you turn the key on multiple times does pressure rise to set point? Does it bleed off?
Old Sep 28, 2009 | 07:19 PM
zl1dreams's Avatar
ill have to check tomorrow. i just have a test guage on the shrader valve for now.
cmdeshon
Dec 27, 2014 10:06 AM
1996LT1Z28
Dec 4, 2014 09:20 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
