Bentley Mulsanne - 6.75L Twin Turbo Pushrod V8
Old Sep 17, 2009 | 10:16 AM
ImportedRoomate's Avatar
505hp 752lbft.
Even Bentley recognizes that you cant beat the good ole pushrod for low end torque.
http://www.autoblog.com/2009/09/15/f...f-torque-at-1/
Old Sep 17, 2009 | 12:27 PM
muckz's Avatar
Couldn't find anywhere in the article that it's a pushrod engine...
Old Sep 17, 2009 | 03:14 PM
Oops, didn't realize that. I heard it from somewhere else. This mentions it though:
http://www.motortrend.com/roadtests/...ook/index.html
Old Sep 17, 2009 | 03:20 PM
Threxx's Avatar
The roots of that engine have been around since the late 60s so I'm not surprised at all that it's a pushrod... back then pushrods were pretty common luxury vehicles. I guess it's still impressive that the basic design has been found to be sustainable for this long, though. According to wiki the only longer-standing engine series is the SBC.
Old Sep 17, 2009 | 03:50 PM
muckz's Avatar
So, the world's most prestigious automobile uses a pushrod engine, and here we are on this board lamenting that GM needs to put "high-feature" engines in its luxury/performance brands to be taken seriously...
Old Sep 17, 2009 | 04:35 PM
JakeRobb's Avatar
Super Moderator
Pushrod vs. DOHC has nothing (directly) to do with low-end torque.
Low-end torque comes from displacement (and appropriate use of said displacement, of course). I refer you to the Bugatti Veyron as an example of a high-displacement, high-torque OHC motor.
The reason you don't find many torquey OHC motors is twofold. One, OHC takes up more space in an engine bay, so they tend to make the motor smaller to compensate.
Two, OHC is more conducive to high RPMs. High RPM is a great way to make power, especially in an engine that is short on torque in the low and mid RPM range. This generally results in camshaft designs that are biased towards higher RPMs, which in turn hurts low-end torque. Modern OHC engines usually have variable valve timing, which helps this to some extent, but the point still stands.
Old Sep 17, 2009 | 06:27 PM
bossco's Avatar
This! and this peaky little DOHCer!!!!!
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
