86 iroc-z overheating tpi 305
Old Sep 13, 2009 | 01:05 AM
2000TA's Avatar
Question 86 iroc-z overheating tpi 305
OK I have a 1986 IROC-Z TPI 305 that is overheating. I Replaced the motor Put in a NEW/Rebuilt AC in it Replaced the water pump and New Radiator. It seems to run at about 200 degrees with the AC off and over 230 with the AC on. I even sent back the Crate motor and replaced it but is still overheating. Shroud is there and Fan is on connected Direct. I am just stumped now. any info can help...
Old Sep 13, 2009 | 07:02 AM
87DJP2001's Avatar
Do you have the air dam in place under the car???? Important item in the cooling system operation.....
Old Oct 6, 2009 | 10:52 PM
2000TA's Avatar
yes I have it.still overheating. I have changed everything too. including the CAT. Still getting hot
Old Oct 8, 2009 | 07:07 AM
Lt1 and Ls1's Avatar
Well that is what I was going to ask. Always make sure that air dam is on there. Do you still have the plastic radiator on the car? I changed mine, and that helped on my 92 and 91
Old Oct 8, 2009 | 07:15 AM
87DJP2001's Avatar
What do you consider being too Hot???? A/C on or off???
Old Oct 8, 2009 | 11:45 AM
n2ceptor's Avatar
What degree thermostat are you running????
G-BODYT56
Jan 14, 2022 11:14 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Pwilson59
Sep 3, 2015 08:47 PM
