low track times anyone help?
Old Sep 11, 2009 | 12:47 PM
meangreenchevy's Avatar
slow track times anyone help?
Cars a 97 ss m6 w/ lt,ory,cai, and a zoom clutch... okay my best time was 14.2 at 102 my first pass: tire pressure at 32psi rpms at 2k and dumped the clutch tires spun bad ran a 14.2 at 101... 2nd pass: tire pressure at 20psi rpms at 2k dumped the clutch car bogged bad ran 14.5 at 100 3rd pass: tire pressure at 20psi rpms at 2500 dumped the clutch car bogged again and ran 14.2 at 102... these numbers seem really high what's wrong and how do I stop the bogging
Old Sep 11, 2009 | 03:07 PM
Trickyrick33's Avatar
Are you running street tires or slicks?
Old Sep 11, 2009 | 04:22 PM
Street tires they are 275/40/17
Old Sep 12, 2009 | 06:15 AM
AL SS590 M6's Avatar
Moderator
What brand? True street tires or drag radials?
Regular street radials should be run at or near their normal running pressure then raise the launch rpm 'till the launch just chirps the tires. That's a tricky chore but it just takes practice.
Old Sep 12, 2009 | 02:45 PM
Z-RATED94's Avatar
If your using the stock 10 bolt I highly doubt you'll ever get a decent launch without breaking it. You'll need some DRs or slicks and about a 5k or higher clutch dump. A m6 needs to have a decent driveline to get it done off the starting line.
PS, Don't forget to put on a drive shaft safety loop.
Old Sep 12, 2009 | 11:34 PM
What AL SS590 M6 said. Leave the pressure at or near the manufacturers recommended rating. Under inflated tires cup which decreases the amount of contact area between the tire and road.
Are you doing a burnout? If so, don't. Overheating street tires causes them to become slimy in a sense.
Old Sep 14, 2009 | 12:12 PM
They are regular street tires I think the brand is raptor and yes I was doing a preaty good burnout to warm up the tires... and as for the 10 bolt well mine just blew a tooth of the pinion gear so have another 10 bolt on the way and I wasent even launching when the rear blew
Old Sep 14, 2009 | 12:17 PM
Also car is not tuned for my mods so I have a check engine light for my rear o2s cause of the ory
Old Sep 15, 2009 | 04:29 PM
Still looking?
Old Sep 15, 2009 | 06:34 PM
LearJet's Avatar
nope
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
