NX system and NOS TB plate
Old Jan 19, 2003 | 02:27 PM
OffspringZ28's Avatar
will this work? one side of the tb plate has an inlet for nitrous where as the other side has an inlet for fuel, i like the idea of a plate system better than the nozzle i have stuck in the intake elbow. What do you guys think? it should be easy enough to transfer.
Old Jan 20, 2003 | 02:45 PM
justahoe's Avatar
I think the nos throttle body is a dry setup. That what it looks like to me in the catalog.
Old Jan 20, 2003 | 10:10 PM
nope, the one ive got has an inlet for both fuel and nitrous. hope it works well.......
Old Jan 21, 2003 | 07:37 PM
Curt (pres AAMC & ZAA)'s Avatar
The NOS throttle body is a dry setup, the NOS throttle body plate is a wet setup. I had a NOS throttle body plate, and it didn't fit very well. I had to grind quite a bit from the IAT housing and the thermostat housing, and I still had fitment problems (I had a BBK throttle body at the time). Looking at my new AS&M TB, I think it would probably work since there's no coolant passage in the IAT housing on this TB and there seems to be plenty of clearance.
I have heard some people having issues with the traction control/cruise control servo motor cables being too short with the plate in place. I didn't have that issue with mine, but I don't have cruise or traction control.
I only ran it a couple of times, and it didn't seem to hit as hard as the NX Shark nozzle, and the plugs on the front two cylinders "read" a little leaner than the others (but not to the point of being a problem). I was only running a 100 shot with it though.
Old Jan 21, 2003 | 08:13 PM
justahoe's Avatar
My bad I was thinking throttle body not plate
Old Jan 21, 2003 | 08:35 PM
volZfrk's Avatar
where can I find one of these NOS plates?
Old Jan 22, 2003 | 09:45 AM
i wont be picking it up as i need the money to pay for a lawyer.... but anywho, volZfrk you can go here....http://www.sffba.net/forum/showthrea...threadid=12036 email him and ship, its yours
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
May 21, 2015 01:04 PM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
