Help with tires sizes?
Old Jan 19, 2003 | 12:20 AM
Korben's Avatar
Whats the largest size tire I can fit on my V6 1996 Camaro without rubbing? I know those LS1 and LT1 boys cna fit 295 in rear and 275 in front, can we do the same without rubbing? And if I can't, can I just swap a SS or Z28 axle with mine? THanks!
Old Jan 19, 2003 | 05:31 PM
Wolfie's Avatar
ours are just like the z28s there, the biggest ive seen up front is 295, with 315 in the back
Old Jan 19, 2003 | 05:40 PM
kahouna23's Avatar
my 275's rub a little when you turn the wheel all the way. Just enough to see a little area on the inner fender well. Not the actual fender. The plastic lining. 295's on the front?!! WOW!!
Old Jan 21, 2003 | 07:46 AM
camaroKID's Avatar
i dont really see the need for 275 or highers on the front. however i know that 275 will fit and 315 in the back will fit, with the proper back spacing.
Old Jan 21, 2003 | 04:02 PM
Korben's Avatar
New question. Say I want to have 295's in the rear and 265's or 255's in the fronts, how owuld I do that? I want the 295's to be 18" and the 265 or 255 to be 17". What would my ratio be for that 18"? 295/35/18? and that 265 or 255? 265/45/17? 255/50/17?
Old Jan 21, 2003 | 05:18 PM
camaroKID's Avatar
first number- width of tire
second number- the size of the side wall
third number- rim size
in my own opinion i think the 255/45/17 are the fitting tire for the f body. with 18's in the rear and 17's up front, i believe that the extra side wall space in the front woulndt be noticable because of the extra rim diameter.
Old Jan 21, 2003 | 11:27 PM
Korben's Avatar
Camarokid, i'm not asking what the sizes mean, i know what they are, but I wanted to make sure my sizes were correct. Different cars have different proportions for each number, and they should be kept in proportion. Thanks for the hlep anways.
Old Jan 22, 2003 | 03:08 PM
94GrayV6's Avatar
I think you should go 275/40/17s and 295/35/18s
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
