Bought a Turbo Corvette, selling my Supercharged Trans Am
Guys I just bought a 93 Turbocharged Corvette. So I will be selling my Supercharged Trans Am. I can't see having two muscle cars at the same time. I'm really bummed because I've owned my TA since it rolled off the assembly line. If you know of anyone looking for a garage kept and babied muscle car let me know. Here is the thread.
https://www.camaroz28.com/forums/sho...30#post6086930
Here is the 93 turbocharged Corvette
Here is the 97 Trans Am WS6 Supercharged
I will always be an Fbody lover. I promise to be humble and not to bag on Fbody owners like some corvette lovers do.LOL The guy I bought it from is on here sometimes as Mn_Vette
Here is a mod list for the TurboVette:
---ENGINE:
-350ci motor Rebuilt about 15k ago
-Custom Comp Cam
-LT1 Intake manifold ported for a 58mmTB and set up for a rear mount distributor, EGR block off plates installed
-Custom 7qt oil pan setup for the turbo kit
-Holley 58mm TB
-Meziere HD electric water pump
-Different starter to fit with the turbo kit
-Alternator and battery replaced within the last year
---FUEL:
-Custom Fuel Rails
-72# injectors
-Aeromotive FPR
-Dual intank walbro pumps with dual supply lines
---CPU:
-ACCEL Gen 7 DFI System
-Accel dual sync distributor with plug wires, allows full sequential injection and eliminates the optispark(opticrap) distributor
-Wideband O2 integrated into the Accel system
-MSD Digital 6 ignition
-Programmable Shift Light
-Laptop with PRO programming key and adjustable laptop stand
---DRIVE TRAIN:
-6 speed Back tag ZF-6 transmission, Basically bullet proof
-Newer Clutch and pressure plate
-McLeod Master cylinder
-D44 Rear end with 3.45:1 gear ratio
--BRAKES:
-Upgraded to C5 corvette brakes in front
-C5 Drilled and slotted rotors
-Doug Rippie Motorsports C4 biasing spring
-Line Lock
---TIRES:
-Chrome ZR-1 Rims, 3 months of use
-315mm tires in the rear, 3 months of use
-255mm tires in the front, older, but in very good condition
---TURBO KIT:
-1 3/4 “ Headers jet hot coated
-2.5” cross over pipe Jet hot coated in black 2000 degree
-3” into turbocharger coated on 2000 degree jet hot
-Turbonetics HP-78 Ball Bearing turbo charger with .96 a/r (a few hundred miles on it)
-Turbonetics Racegate with black spring
-3.5” down pipe jet hot coated in 1500 degree sterling finish
y-connector to dual 2 ¾” pipes
through dual 3” pass through mufflers and out dual 3” rolled stainless steel tips
-large IC in front of radiator
-Intake piping all jet hot sterling coated
-Tial 50mm BOV
- Boost gauge and fuel pressure gauge on a dual A-Pillar holder
---ENGINE:
-Custom Comp Cam
-Holley 58mm TB
---FUEL:
-Custom Fuel Rails
-72# injectors
-Aeromotive FPR
---CPU:
---DRIVE TRAIN:
--BRAKES:
-Line Lock
---TIRES:
---TURBO KIT:
-Tial 50mm BOV
Don't have any numbers on it yet. I haven't driven it because I'm still in Iraq. My girlfriend flew to Detroit and drove it to Kentucky for me. I'm guessing around 500rwhp at 8psi. The corvette is about 300 pds lighter than my TA. The only problem with Corvette's is the fact that the rear ends are so weak compared to my 9". He gave me a boost controller and meth kit to install and I should be able to up the boost considerably. It has stock pistons in it. Oh well I have a spare block in my garage just waiting to make a 383 out of.
Thanks. I can't wait to get back in the US. Not being able to drive the car is driving me crazy. I have to live vicariously through my girlfriend who has driven it a little. I'm having a hard time resisting buying a bunch of parts while I'm stuck in Iraq. Oh well... only 6 more months.
Thanks dude... keep us posted when you back. i'd like to hear what the new setup puts down!
