so i checked my ring gap......
Old Jul 27, 2009 | 12:03 AM
paxtonLT1's Avatar
my pre gaped rings are at "0014-"0016 top ring and around "0010 bottom. so they need to be filed but to what? im at less then 6si with a 30 over bore the kb piston guide says 0.0050 ring gap factor for street n20 or supercharger but what dose that mean sorry if im not geting somthing and thanks for your guys help.
Old Jul 28, 2009 | 09:45 PM
paxtonLT1's Avatar
ok so it looks like i came up with4.30 x .0050 = 0.0215 that sound right for the top ring? what about the second ring? the same? kb says that the second rings dont need as much extra clearance... http://www.kb-silvolite.com/article....n=read&A_id=32 thanks guys.
Old Jul 29, 2009 | 06:42 PM
boosted-lt1's Avatar
4.030" x 0.005 = 0.020" (not 4.30" bore)
Second ring should be run with more clearance. Here is some reference info.
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
http://www.cppistons.com/LinkClick.a...j8%3D&tabid=75
At 6psi run the tighter recommendation. At ~15+ or race motor run the looser recommended. I think that would be safe.
Scott.
Old Jul 29, 2009 | 08:43 PM
paxtonLT1's Avatar
top ring gap is now at .019 thanks for your help
Old Jul 30, 2009 | 03:51 PM
Sure thing. Good luck and have fun.
-Scott.
Old Jul 30, 2009 | 08:15 PM
paxtonLT1's Avatar
ok i talked to the kp tech guy and he says .020 top ring and .016 second ring do to the piston disign. seems tight for the second ring right i mean i think the chilton says .018 min.
Old Jul 30, 2009 | 11:03 PM
roguedriver's Avatar
I think thats too tight, especially for boost, even though your only running 6psi. I'd run them bigger then that, and would probably recommend planning ahead and going even bigger. Think Boosted is right also about the bigger 2nd ring gap. I probably wouldn't go any smaller then .020 top .022 2nd. Probably slightly bigger. Hopefully more will chime in here. I think i set mine up to .028/.029.
Ken R.
Old Jul 31, 2009 | 11:59 PM
paxtonLT1's Avatar
im confused i think im going to give them a call and dubble check he could have misunderstood me or somthing right now i have them at .020 top and .018 second. thanks for your guys help.
Old Aug 7, 2009 | 10:48 AM
jsetzer's Avatar
Old school always said run a tighter bottom to help trap anything that gets past the first. Practice and testing has shown more power and better results with a tighter top ring. I'm sure theres plenty of info if you want to search.
But yes go a little on the loose side. I am @ .035 on a 650ish hp motor.
Old Aug 7, 2009 | 06:35 PM
Hal Fisher's Avatar
Old school may not be taking in to account forced induction. With forced you don't want pressure left in the middle to cause ring bind.
Hal
Old Aug 7, 2009 | 09:15 PM
paxtonLT1's Avatar
well i talked to the kb tech guys again and they say .020 top ring and .016 second ring... so i ended up playing it a little safer and went with .022 and .018 i think i might endup runing e85 and a small shot of n20 but well see what what hapens. thanks for your help guys.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
