High idle speed
Old Jan 16, 2003 | 08:47 PM
Snake Slayer's Avatar
High idle speed
I recently purchased a 98 z 6-speed and the car runs great but it idles at 1100 rpm. I've owned ls1's in the past and every one idled at like 8-900 rpm. It also runs really cool too, about 170 or 180. All the others ones I've had run at a little below the 210 mark. I'm thinking maybe someone put a 160 degree thermostat in it. Any ideas, I'm clueless about this. Thanks for any help!
Old Jan 16, 2003 | 08:55 PM
lastZ's Avatar
2002 z-28 -my car idles right around there too, no big deal, and as far as your car running temps like that, be thankful ,heat kills performance.....nothing to worry about!
Old Jan 16, 2003 | 11:30 PM
gearslammer's Avatar
[QUOTE]Originally posted by lastZ
[B]2002 z-28 -my car idles right around there too
ditto
Old Jan 17, 2003 | 12:19 AM
OnyxXtreme's Avatar
snake - mine is exactly like yours.....idles at 1100 at startup, and 1000 when the motor warms up
and always runs cool
i was told at ls1tech, that sometimes the tach just gets a bit off, when it says its idling at 1000, it could actually be 8-900
Old Jan 17, 2003 | 01:44 AM
stik6shift98's Avatar
mine idles like that too but temp is high even tho i have a 160 thermo
Old Jan 17, 2003 | 12:58 PM
98whiteZ28's Avatar
i have that too idles at about 1000 and runs really cool compared to my old camaro.... so theres no worried just ls1's vary i spose.
Old Jan 17, 2003 | 01:01 PM
PhantomTA's Avatar
Moderator
its just a variance in the tach readings
my car would idle at like 700-775 stock and would read 1000ish
Old Apr 30, 2003 | 08:15 AM
therealmagyver's Avatar
It's actually idling at 850
On the tach it shows 1100, but yesterday I plugged up to a computer and it's really 850...so that is the good news.
The bad news is the temperature on the computer showed my car to be 17 degrees hotter then what the gauge shows.
Old May 4, 2003 | 02:28 AM
fbird95's Avatar
It idles high when you turn it on cause of the choke
Old May 4, 2003 | 12:41 PM
Ferocity02's Avatar
At startup mine is at 1100 RPM's then drops to about 600 in a matter of seconds
Old May 4, 2003 | 01:55 PM
fbird95's Avatar
Not sure how normal that drop right away and to 600 rpms is, But i have learned the hard way many times over the years, that if it aint broke dont fix it. If the car runs fine now, leave it alone. Many times something like that would concern me and i would get it fixed only to have a worse problem, suddenly i would wish it just was the way it was before i fixed it.
Old May 4, 2003 | 06:52 PM
GoFast908Z's Avatar
Member
The reason you see it running cooler is because 99-02 F-Body cars have the computer tuned to show the temp at 210 in normal driving conditions. The 98's actually have a somewhat accurate temp guage. 170-180 is normal on a 98 without a low temp thermo. 99-02 cars are nowhere close to accurate on the temp guage.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
edman
Mar 13, 2015 09:39 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
edman
Jan 25, 2015 02:41 PM
