cold start up closed tps timing
Old Jul 14, 2009 | 04:39 PM
93z383's Avatar
Ive noticed that in the past few logs, my timing is off at start up compared to the closed tps vs rpm. By as much as 5-7 degrees lower than on the table, in park, Has anyone noticed this and what might be causeing it. The lower timing is effecting the vacuum, and I need all I can get for the brakes.
Old Jul 15, 2009 | 12:28 AM
MikeGyver's Avatar
? you need all the vacuum u can get for your brakes during start up?
Old Jul 15, 2009 | 05:26 AM
93z383's Avatar
NO, is not like it sounds, I need all the vacuum for my brakes all the time, its just when the timing is lower I have a lower vacuum, not much but alittle. And if the timing is retarded when its cold by 4-7 degrees it gets me alittle less vacuum...I really didnt need to include that line but oh well.
Old Jul 16, 2009 | 07:26 PM
irocbsa's Avatar
Check out the "Spark Correction vs. MAP vs. Coolant Temp" table. Also, as an additional task, make sure that your "Main Spark Advance" table will blend well into your closed TPS spark table for the appropriate speed/load points.
Gtpguy
Jan 26, 2015 04:50 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
Britbilly
Jan 7, 2015 08:49 PM
Collector Car
Jan 5, 2015 10:58 AM
jayblev95
Dec 1, 2014 06:55 AM
