4l60e trouble
Old Jul 11, 2009 | 11:28 PM
wheelliftnpony's Avatar
4l60e trouble
having problems with this stinkin transmission shifting to third. it will bounce off rev 3 or 4 times before shifting.. 1-2 is fine and 3-4 is fine. and i know very little about auto trannys. could this be from an improper fluid level? it might be over filled a little... i have TCI internals and a B&M shift kit, stock converter. this is killing my 1/4 mile time. i know this car is capable of 12s, but it just wont shift 2-3 when wide open. i have to let off for it to shift. but thats just as bad.. any help is appreciated, chris
Old Jul 12, 2009 | 12:07 PM
Performabuilt's Avatar
Supporting Vendor
Stck stall? Any tuning done?
Old Jul 12, 2009 | 04:23 PM
stock stall, computer only tuned for minor engine mods
Old Jul 12, 2009 | 07:34 PM
Supporting Vendor
Its possible you just have the shift point set to close to the rev limiter , You do need to bear in mind theres alot more going on with the 2-3 shift than there other gears its a more comlicated and uses and overlap apply-one conponent while releasing another. So it hydraulically takes a little more time to complete. Sometimes thats not accounted for in tuning and all the shifts are set to happen at the same RPM and of course that may not work on the 2-3.
Old Jul 13, 2009 | 10:20 PM
its already shifting at 6200, is it ok to adjust the limiter higher than that?(about 6300)
Old Jul 14, 2009 | 07:29 AM
LearJet's Avatar
try setting the shift sooner instead.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
