clutch disengagement problems
Old Jul 11, 2009 | 07:04 PM
arctic white 94's Avatar
I just rebuilt my motor and installed it back in the car. I can shift the car fine when it is not running but when it is running the car will not shift. I'm pretty sure the slave cylinder is in correctly. The clutch feels fine. Does it sound like it needs to be bled? Also we used two different bolts that do not have shoulders around the head for the clutch. We put them across from each other but could this be part of the problem?
It's a 95 six speed z28.
Please help.
Old Jul 14, 2009 | 11:01 PM
does anyone have any ideas?
Old Jul 15, 2009 | 07:22 AM
97pontta's Avatar
Did you remove the slave or master from the hyd. system? If so you may need to bleed the system. Also check to see if your clutch is dragging, not fully releasing. The way I've checked is put the rear axle on jack stands just enough to get the rear tires off the ground. With the engine running put the trans in 1st gear and keep clutch pedal to the floor. Check to see if the rear tires are turning at all and do this a few times. If the wheels are not turning rev the engine quickly to 3000-4000 RPM a few times and see if the wheels rotate when doing this.
Old Jul 15, 2009 | 11:28 AM
yes we removed the slave cylinder. the master cylinder was low but it was not completely dry.
Old Jul 15, 2009 | 01:01 PM
97pontta's Avatar
If you removed the slave you need to blead the system, there is a good chance there is air in the system.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
