bcm wiring
Old Jul 7, 2009 | 06:26 PM
steve40's Avatar
bcm wiring
anyone have a wiring diagram for the bcm? well i'm pretty sure its the bcm. a light blue rectangular connector by the glove box, not sure of the original location, since it had to move cause of the cage.
want to know if it could affect shutting down the signal to the fuel pump?
Old Jul 7, 2009 | 07:00 PM
http://shbox.com/1/bcm_1996.jpg
The BCM does not control the fuel pump. However, the fuel enable signal from the VATS portion of it does go to the PCM and without it the injectors will not fire.
Old Jul 7, 2009 | 08:30 PM
steve40's Avatar
thanks, since i'm dumb do you have the pinouts? the connector looks like it had a short on it.
Old Jul 7, 2009 | 10:12 PM
The pinouts are on the schematic.
C1 (6 pin) is green.
C2 (6 pin) is black.
C3 (32 pin) is blue.
I'll try to edit the diagram to show the connector faces.
[edit] Ok, connector faces now shown on the bottom of the schematic.
Old Jul 8, 2009 | 04:57 AM
steve40's Avatar
sweet...thanks for your help.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
