95 z28 Headlight problem
Old Jul 6, 2009 | 11:43 PM
SmokeyBlaZe's Avatar
Question 95 z28 Headlight problem
Well this is my second camaro , the first one was a 93 and they both have this problem. The Right Low Beam sometimes doesn't come on but If I pop the hood and close it the Headlamp comes on. Is the bulb loose or something? If I remember correctly the bulbs and lamp are One piece, I hate to replace the whole headlamp. Because I know the new one is gonna look totally different than the other three. Anybody else ever have this problem? Solutions? Will I have to remove the Header panel to check the bulb out?
Old Jul 7, 2009 | 07:46 AM
Could be the sealed beam or the connection. The owner's manual has instructions on how to remove the beam (two torx screws from the front-pretty easy). If you want, you can swap it with the other side and see if the trouble follows.
ldtantlinger92
Jan 19, 2015 01:26 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
