Ignition switch replaced, and key is stuck!!
Old Jul 3, 2009 | 10:38 AM
JasonK94Z's Avatar
Exclamation Ignition switch replaced, and key is stuck!!
I have the steering column out in the garage, and replaced the igition switch. I tested it out, but noy my damned key is stuck in the "on" position. Whats wrong? Is it the tumbler?
Old Jul 3, 2009 | 11:24 AM
Did you get the switch adjusted properly?
http://shbox.com/ignsw/ign_switch_repl.html
Try taking the rod off the switch and see if the key/tumbler moves freely.
Old Jul 3, 2009 | 11:42 AM
JasonK94Z's Avatar
The switch is off and its still stuck. Have a guide on pulling the steering wheel to replace the cylinder? Also, can I bypass the VATS when I get a plain key?
Old Jul 3, 2009 | 12:53 PM
No guide for the key cylinder. Yes you can bypass VATS. Info on my website.
Old Jul 3, 2009 | 02:01 PM
JasonK94Z's Avatar
Thanks! I found the bypass diagram. The ignition lock/cylinder is apparantely bad and will need replacing. I got the airbag off but I need a steering wheel puller. I have a guy coming tomorrow to the house for $40 to pull the steering wheel and put the new cylinder in for me. I'm getting into some unknown territory with this and would rather have an experienced person do this part for me.
liamcg97
Nov 25, 2019 05:55 PM
Dzmaro
Jan 25, 2015 10:39 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
tds1213
Nov 27, 2014 12:55 PM
